Quick question to check if someone has ever encountered the same or a similar issue with the Cognos BI Integrated Security Mode.
Issue we are facing is the following:
- TM1 Model is integrated with BI security through the IntegratedSecurityMode = 5 and ServerCAMURI and ClientCAMURI parameters in the tm1s.cfg file
- Within BI, the Active Directory Users are stored in specific Cognos BI user groups
- These BI groups are also used in TM1 to setup specific security on cubes, dimensions, etc. by group
- From my understanding with this setup, you then no longer need to maintain the client - group mappings within TM1 manually, these are synchronized with the mappings you have set up in BI
- However, when a user logs in, belonging to a certain group in BI, he does not get the required checkmark in the Client-Groups settings in TM1 and can therefore not access any of the cubes.
- If you set the check manually in TM1, it disappears again as of the moment the user logs in again.
Any insights or tips are more than welcome!
Mathias
