No read access to elements, cannot view
Posted: Thu Nov 28, 2013 11:06 am
Hello, forumers.
I got a problem with saving view with two dimension dynamic subset. MDX expression is
I need to filter one dimension by correspondance with another dimension in context. In this case choosing context dimension element will lead to update dynamic subset. Filtering is based on text attributes named 'test1' of two dimensions Dyn_dimA and Dyn_dimB.
Works fine.
In my cube there are four dimensions Dyn_dimA, Dyn_dimB, Dyn_dimC, Dyn_dimD. Two last are dummy dimensions with several simple elements.
When I try to save a view where dynamic subset is placed in context, I got error. But I already have got such view (dynamic subset in context) in another model without any issue.
What may be the reason? I'm admin in the model.
{filter ({tm1subsetall ([Dyn_dimA])}, [Dyn_dimA].[test1] = [Dyn_dimB].[test1])}Works fine.
