Audit requirements - user login creation datestamp
Ajay
Version: 10.2.0, PA 2.0.9
Post by Ajay »
Hi All
It is that time when auditors are crawling around and i need to provide some kind of record to show when user logins were created on the system.
I've looked through the control cubes but couldn't find a specific one which shows when a login is created.
Any ideas ?
Ajay
Re: Audit requirements - user login creation datestamp
Ajay wrote:Hi All
Any ideas ?
You won't find it in any of the cubes. I haven't examined all of the new metadata logging in 9.4 yet, and there may be something specific in there... but then, you aren't on that version anyway.
Failing that, probably the best way of finding it is to search the log files for all instances of a change in the Password element of the }ClientProperties cube. (Assuming that you don't let them have their login without a password, or the sods will never add one!) It should be a simple case of then filtering out the oldest change (which will probably be by an Admin rather than the user) which will tell you when the account was created.
