Problem with TM1 Dimensions
Posted: Thu Nov 14, 2013 3:41 pm
TM1 Version 10.1.1, issue using 'Pick Element' feature in MS Excel 2010.
We have various dimensions prefixed with 'x.' for example x.account or x.business unit. When I try to use 'Pick Element' in Excel and select any of the x.*** dimensions, subset editor opens but is completely empty. Pressing the 'All' icon does nothing and the subsets drop down is also empty. For reference the dimensions without the x. prefix work as expected.
These x. dimensions are used in various cubes, and work fine in cube viewer. I can open each of them and select from the list in subset editor when accessed via cube viewer. This problem only presents itself when using 'Pick Dimension' or 'Pick Element'.
I manually created an 'x.test' dimension and added a parent with 2 children to the new dimension. I then saved it and tried to access it via 'Pick Element'. Again it was blank.
From here:
http://www-01.ibm.com/support/docview.w ... wg27024713
I can see that 'AllowableChars[] = ".$%_`";'
Has anyone encountered this before, and is there a fix?
Thanks, Tom
From here:
Thanks, Tom
