Is it possible to pass TI Parameter variables to a dos batch file?
I can call a DOS batch file using the following:
ExecuteCommand('C:\test.cmd', 1);
and everything works fine. However, if I try to add parameters, the .cmd file won't run...
ExecuteCommand('C:\test.cmd p1 p2', 1);
any thoughts?
thanks!
Passing TI Parameters to a DOS .cmd file
- Mike Cowie
- Version: Anything thru 11.x
Re: Passing TI Parameters to a DOS .cmd file
Have you looked at the TI EXPAND function? It takes a string containing references to TI variables (which parameters are) and "expands" the contents of the variable into the string. So, using your example:
Here I'm assuming that you have 2 TI parameters (both String type) called p1 and p2.
As far as how it works, let's say you have the following values:
Hope that helps.
ExecuteCommand(EXPAND( 'C:\test.cmd %p1% %p2%' ), 1);As far as how it works, let's say you have the following values:
- p1=Hello
- p2=World
ExecuteCommand('C:\test.cmd Hello World', 1);Regards,
Mike Cowie
QueBIT Consulting, LLC
- kielmc
- Version: 10.2.2 FP4
- Excel Version: 2013
Thanks Mike, that function is exactly what I'm looking for!
