When I try to change the attribute of a dimension in Tm1 Web sheet I am getting this error message.
I have given the user group write access to both the cube and dimension.
Object Security No write Rights
Re: Object Security No write Rights
When you say "the cube and the dimension", are you talking about the data cube and dimension, or the attributes cube and dimension?Abinaya wrote:Hi
Abinaya
- Version: 9.5.2
- Excel Version: 2003
For data cube and dimension by right clicking and going to security assignments. Also write access through through }ElementAttributes_dim.Alan Kirk wrote:When you say "the cube and the dimension", are you talking about the data cube and dimension, or the attributes cube and dimension?Abinaya wrote:Hi
