TM1 Mobile Contributor with Cognos Express 10.2.1
Matya
Post by Matya »
Hi Guys!
Have anybody ever configured the TM1 Mobile Contributor application with Cognos Express 10.2.1?
I installed the CX and made a test application. It works properly with TM1 Applications Web (Contributor) and with the Cognos Insight too, but I can’t log in with the TM1 Mobile Contributor.
I set up the the host and the server port and the Login window appears, but I can’t log in with an admin user. The user is an admin user at the TM1 data server and it has Submit right for the whole application.
The error massage: ERROR - The credentials provided are invalid. Please try again.
Do You have any idea what the problem is? (the user name and the pw are correct for sure ;) )
Thx,
Matya
Version: PA 2.0.7
Re: TM1 Mobile Contributor with Cognos Express 10.2.1
Post by jim wood »
Have you tried creating a none admin user and assigning them as submitter for some items to test the login?
Matya
Post by Matya »
Hi Jim!
Txh for your answer.
Yes, I've tried to login with a "normal" user too, but I got the same error massage.
I have no idea. :(
