I am having some problem on the cube view source.
I created a process and change the source into cube view.
however the map tab is not shown in the performance modeler and in architect the map tab is grey out.
I have using the same process in TM1 10.1.0
I am wondering is there a bug or it is my creation is incorrect?
TM 10.1.1 CubeView Source
Charles Ang
- TM1 Map tab.png (39.15 KiB) Viewed 2975 times
failurehappening
Re: TM 10.1.1 CubeView Source
Hi Charles
Try saving the process, closing it, then going back into the process.
RHR
What about the Variables tab. Do you have any of the variables defined as Elements? The Maps tab does not show up unless there is at least one variable defined as Element. Changing a data source can blow away your variable definitions if you don't answer all the prompts correctly.
