Element unlocking Bug?
Posted: Tue Oct 29, 2013 5:05 pm
Hi all
I created a TI to lock and unlock an individual element within a dimension using a TI to send the tm1users name to the properties cube Lock attribute, It works for an Admin but when a normal user uses the process it works perfectly for the Locking however for the unlocking it removes the name in the properties cube but still leaves it locked and greyed out,
I have tried updating the security settings but it remains locked until an admin unlocks it again. Is this normal behaviour? If there is no name in the cube should it not unlock straight away?
heres my code
is this a bug?
thanks all
heres my code
pType = # parameter set when running
pUser= TM1User();
pCube = '}ElementProperties_Year';
pOpt1= '2013';
cubelockoverride(1);
#Lock an Element
if(pType@='Lock');
CellPutS(pUser,pCube,pOpt1,'Lock') ;
endif;
#Unlock an Element
if(pType@='Unlock');
CellPutS('',pCube,pOpt1,'Lock') ;
endif;
thanks all
