Cube dimensions (aliases) won't show in FM Metadata wizard
Posted: Tue Oct 29, 2013 9:52 am
by jorgen.skovly
Hi!
We are publishing multiple TM1 cubes through Framework Manager to the BI Content Store so that we can consume them in Cognos BI Report Studio.
We have successfully exposed and consumed several cubes in Report Studio. However, when trying to publish one specific package, no dimensions show under the "Select Locales" (aliases) part. This is quite strange to me, as this cube is sharing most of its dimensions with the other cubes that we successfully have been able to publish and consume. Regardless, I have verified that my user has access privileges to all the dimensions in this cube specifically.
I have also made sure that we have chosen / specified a Measures Dimension and a Time Dimension in TM1. However, in this cube the Measures Dimension chosen is different from the other cubes that we have published. Are there any requirements for the choice of Measures Dimensions when publishing TM1-cubes through FM?
Other than that, I am completely clueless as to what could be the reason for this problem.
Any input / thoughts would be highly appreciated. Thanks!
Version: TM1 10.1.1
Cognos Framework Manager 10.2
Re: Cube dimensions (aliases) won't show in FM Metadata wiza
Posted: Thu Oct 31, 2013 7:39 am
by jorgen.skovly
Little input on this case so far! Anyone need more details in order to be able to provide any input?
If so, please let me know what kind of details you want, and I will be happy to attempt to provide them!
Thanks!
Posted: Thu Oct 31, 2013 10:00 am
by jorgen.skovly
Follow-up: The two different dimensions used as measure dimension are actually defined as different dimension types; In those cubes where one is able to select locales (aliases) during FM package creation, the measures dimension is of type "calculation", whereas the measures dimension in the cube where one is not able to select locales, the measures dimension is of type "Version".
Still wondering if anyone knows of any requirements to the TM1 cubes that are used as model for FM packages in order to be able to select locales (aliases)?
Posted: Thu Oct 31, 2013 11:05 pm
by macsir
Do you really have existing alias for this dimension? Or you can put some snapshots to clarify your issue.
Posted: Mon Nov 04, 2013 12:13 pm
by jorgen.skovly
Sorry for the delay in response!
I have now verified that all dimensions in both cubes have existing aliases.
Okay, let me try to be more specific.
I have two cubes with overlapping sets of dimensions. An example could be:
Cube1:
- Dimension1
- Dimension2
- Dimension3
- Dimension4 [Time Dimension]
- Dimension5 [Measures Dimension] -> Defined as "Calculation"
Cube2:
- Dimension1
- Dimension2
- Dimension3
- Dimension6 [Time Dimension]
- Dimension7 [Measures Dimension] -> Defined as "Version"
As you can see, Dimension 1, 2 and 3 are part of both cubes, whereas Dimension 4+5 are only part of Cube 1 and Dimension 6+7 are only part of Cube 2.
When running the Model Metadata wizard in FM on Cube 1, one is able to select locales (aliases) on all dimensions. However, when running the same wizard on Cube 2, no dimensions are shown in the Select Locales section (as can be seen here http://i.imgur.com/sVsOAkw.png).
Any idea as to why this happens?
Posted: Mon Nov 04, 2013 10:52 pm
by macsir
That is strange. So, basically you can see cube2 in FM but can't see any dim from there?
As you already stated that you have checked all privilege for the cube and dimensions for the TM1 user in Cognos configuration, I assume there is no issue there.
Have you tried create another copy of cube2 with same dimensions and check it in FM? And why would you use version dim as your measure dimension?
Posted: Tue Nov 05, 2013 1:53 pm
by jorgen.skovly
macsir wrote:That is strange. So, basically you can see cube2 in FM but can't see any dim from there?
Correct.
No, I haven't as I'm only consuming these cubes that have been / are created by others. I have asked the same question about the measures dimension, but my TM1 knowledge was too limited to make me understand the answer.
I'll see if I can make them create a copy of cube2.
Thanks for the input!
Posted: Tue Nov 05, 2013 10:35 pm
by macsir
Ok, as these cubes and dimensions are created by others, I strongly recommend you to check the privilege in TM1 for the user which is used in cognos configuration to see if that user has permission to read dim6 and dim7.
Posted: Fri Dec 13, 2013 12:00 am
by balcey
HI jorgen.skovly,
I'm exactly facing the same issues as you.
Did you able to work whats causing this? You help is much appreciated.
Balcey
Posted: Sun Dec 15, 2013 9:27 pm
by balcey
Correct.
HI jorgen.skovly,
Balcey
Posted: Tue Jan 07, 2014 5:21 pm
by jorgen.skovly
Hi Balcey,
Sorry, but I did not find a solution to the problem! An IBM consultant suggested that the cube might be corrupted, but we never really solved it.
I ended up using a different cube.
Sorry for the late response, for some reason I did not receive any notifications about your comments!
Posted: Mon Jan 13, 2014 1:38 am
by balcey
Hi jorgen.skovly,
No worries, thansk for your reply.
I'm able to solve the problem by re -creating the cube in TM1.
Balcey
