[SOLVED] Strange behaviour with formula
moritz
Version: 10.1.1
Excel Version: Excel 2010
Post by moritz »
Hello guys,
something is wrong with my code:
Sparte_PK='FALSCH';
pos=SCAN('HUS', Team);
if(pos>0);
Sparte_PK='HUS';
EndIf;
When i import my csv file via turbo integrator,
the element "FALSCH" is the only one what gets filled with data.
Although the example value displays "HUS":
Re: Strange behaviour with formula
Can you please be more clear on the purpose?
Also, your screenshot is too small, we cannot see the variables names.
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Post by Michel Zijlema »
Hi moritz,
In the screenshot I see that the transformation code is only defined on the MetaData tab, not on the Data tab. Where are you loading your data?
Michel
moritz
Version: 10.1.1
Post by moritz »
Thank you for your quick support. :)
I just had to check the box "Daten".
Thank you very much and Greetings from Germany!
Re: [SOLVED] Strange behaviour with formula
Keinen Dank !
Wim Gielis wrote:Keinen Dank !
I think you mean nichts zu danken. :)
Indeed, what was I thinking again ? :-)
