Dynamic subset in TM1
phathoang149
OLAP Product: IBM cognos TM1
Version: 10.1.1
Post by phathoang149 »
Hello everyone
I want create dynamic subset.
I Have [Cube 1] and [Cube 2] the same image:
I Want create dynamic subset for [number] demention by expresstion window MDX
Purpose: when I select A in CUBE 2, CUBE 2 only dislay [number]: 1,2,4,6,8,10 as data from CUBE 1
When I select B in CUBE 2, CUBE 2 only dislay [number]: 3,5,7,9,10 as data from CUBE 1
phathoang149
Version: 10.1.1
Re: HELP ME! DYNAMIC SUBSET IN TM1
Help me! Please
phathoang149 wrote:Help me create dynamic subset.
Is this a command, or do you have a friendly question?
phathoang149 wrote:Help me! I'm really Worry.
You mean "worried" ?
And why? it is only TM1, it's not about life and death.
Did you pay attention to the forum rules? And to other general etiquette at online forums?
It's inappropriate to USE CAPITALIZED LETTERS. IT LOOKS LIKE YOU ARE SCREAMING, ISN'T IT ?
Why do you put "HELP ME" in the topic title? Do you think you will be better served?
By the way, most people enjoy their weekend, forum activity is quite low. Bumping is not needed.
In the meantime, what did you do to solve your own question?
phathoang149
Version: 10.1.1
Thanks your command,If you know my problem, please help me! Thanks so much!
java_to_tm1
Excel Version: Excel 2010
Re: Dynamic subset in TM1
Post by java_to_tm1 »
Seems to me that static subsets should do the job?
Open subset editor, select the elements you want ( 1,2,4,6,8,10), remove other elements, and save the subset as A.
Rinse and repeat for subset B.
Why would you need "dynamic" subsets for this?
The Java_to_TM1 Convert
TM1 Version 10.1, 10.2, Cognos Insight 10.1, 10.2
Local: Windows 7 Professional, Excel 2007
Server: Windows Server 2008 64-bit
p.s. I have a healthy disregard for Performance Muddler.
phathoang149
Version: 10.1.1
java_to_tm1 wrote:Seems to me that static subsets should do the job?
Thanks your command.
- IF I use static subset, I can't autoupdate element when i insert element number in dimension. And can't filter number when I select A or B in cube 2.
But my problem is:
- I create 1 dynamic subset is name [Dynamic A] with MDX
- I create view in Cube 2 use subset [Dynamic A]
- When i select A, number dislay 1,2,4,6,8,10 as image
-But when i select B,number dislay 1,2,4,6,8 ,10 not 3,5,7,9. In cube 1 numer for type B is 3,5,7,9
can you help me only 1 dynamic subset i can filter A, B in cube 1 when I select A or B in cube 2. Thanks so much.
Have you tried using the CurrentMember property of the "Type" dimension? As long as the element name is an exact match to the cube cell value and not an alias then I see no reason why this shouldn't work.
phathoang149
Version: 10.1.1
lotsaram wrote:Have you tried using the CurrentMember property of the "Type" dimension? As long as the element name is an exact match to the cube cell value and not an alias then I see no reason why this shouldn't work.
I don't understand your idea. You can help me MDX? Thanks you so much!
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Post by BariAbdul »
Hi phathoang149 ,This is very good MDX resource/doc,Please go through it.
http://goo.gl/hN9j4R
phathoang149
Version: 10.1.1
BariAbdul wrote:Hi phathoang149 ,This is very good MDX resource/doc,Please go through it.
I read it, but i can't solve my problem, help me?
Your MDX query is almost dynamic in the way you want it but the "A" is hardcoded... so you need to make the A dynamic... Lotsaram has directed you to the currentmember function and BariAbdul has directed you to a comprehensive explanation of TM1 MDX. You have all the pieces you need, now you just need to slot them together - what have you tried since receiving these 2 pieces of information?
If Cube A was an attribute cube, instead of a regular cube, then it would be quite easy and your MDX would look something like:
{FILTER( {TM1SUBSETALL( [Number] )}, [Number].[Type] = [Type].CurrentMember)}
You may have to play with the syntax but the concept should work.
