Can you please provide me the TI script which will be used to copy the data from one version to other version.
along with Parameters.
Ashok
Copy Process from one version to Other version using TI
Acc_Moonwalk
- Version: 9.4
- Excel Version: 2003
- Harvey
- Version: TM1 8.3 onwards
- Excel Version: 2003 onwards
Re: Copy Process from one version to Other version using TI
Sorry, your question is way too general for a definitive answer. Make sure you read the "Requests for Assistance Guidelines" for the forum.
In the absence of more information, I would suggest you start by referring to the TM1 documentation, and look into Bedrock. The latter will make your task much easier!
Or use Performence Modeler if your TM1 version is at least version 10 (though I see 9.4 in your profile - is that information up to date ?).
Or search the forum. Code to create views programmatically and zero out data, has been discussed many times before.
Or use Google on well-chosen TI function names.
BariAbdul
- Version: PAW 2.0.8
- Excel Version: 2019
Hi Acc_Moonwalk,This could be exactly what you looking for:
https://www.youtube.com/watch?v=HLhAl5jtK-g
