I have been trying unsuccessfully to run the following vbscript via an executecommand in a TI process.
There is the code:
vFileToUpdate='D:\TM1\Admin\Code\ListTest.txt';
vLineId='NextLine';
vNewText='3:48';
C_Update='cmd /c VBReplace.vbs "' | vFileToUpdate | '" "' | vLineID | '" "' | vNewText | ' " ';
ExecuteCommand(C_Update,0);
The VBReplace.vbs is located in the same data directory as the TI process
I am able to run the script from a .bat in the data directory (for testing purposes)
Using ASCIIOUTPUT, I can see that my C_Update string works; I have taken the output and run it successfully from the cmd prompt
The TI says it was successfully run
This command DOES work, so it seems it just wont run the VBScript:
#C_Update='cmd /c VBReplace.vbs "' | vFileToUpdate | '" "' | vLineID | '" "' | vNewText | ' " ';
C_Update='cmd /c dir D:\TM1\tm1test\Data > D:\TM1\Test2.txt';
Can you help?
