A View can't be deleted?
macsir
Version: PAL 2.0.9
Post by macsir »
Has anyone met this before? Trying to delete }Bedrock view but TM1 refused. :(
EvgenyT
Version: PAL 2.0.8
Re: A View can't be deleted?
Post by EvgenyT »
it seems like '}' is treated as a control objected and gets locked. Run view delete process that deletes views starting with '}' ... should be part of bedrock library as far as I can recall..
Else I can give you TI's that I wrote that delete views/subsets based on search string :)
ET
macsir
Version: PAL 2.0.9
Post by macsir »
EvgenyT wrote:it seems like '}' is treated as a control objected and gets locked. Run view delete process that deletes views starting with '}' ... should be part of bedrock library as far as I can recall..
ET
Thanks, Mate. I manage to do that. :D
EvgenyT
Version: PAL 2.0.8
Post by EvgenyT »
all good ;)
