Filter Dimension Year in cube
ChauBSD
Post by ChauBSD »
Hi everyone,
I have two cube :
Cube A: i input data start year = 2013 (type simple)
Cube B: I want filter Dimension Year and start year 2013. I am using subset dynamix -> Expression windown -> write FILTER but i can't .
({FILTER( {TM1SubsetAll( [SL_Times] )}, [SL_Times].
 = DB('DienGiaiGiaDinh',!DuAn,'NamBatDauThucHien','Value'))})
[attachment=0]Hinh.jpg[/attachment]
How do it ????
Re: Filter Dimension Year in cube
You are mixing up MDX language and TM1 rules language.
Search for "MDX Primer" and this will help you out.
EvgenyT
Version: PAL 2.0.8
Post by EvgenyT »
ChausBSD,
As lotsaram pointed out you are mixing two different languages. DB(..) is used in TM1 rules.
Try something like that .... [SL_Times].
 = [CubeName].(StrToMember("[Dim1].[Element],[Dim1].[Element2],etc "),[Measure].[Value/String] ))}
Referencing cube values in the mdx is bit of a pain in the butt, so you may have to play around with the syntax/ read "mdx primer" to get it working the way you want it.
Do you agree lotsaram?
ET
