Allocation best practice advice and help with rules needed
Sighurd
Version: 10.2.2fp6
Post by Sighurd »
I have a history of sales by product types and product lines (dimension 't-l'), by product managers ('pm'). I have a forecast from marketing department on a summary level - by product types. I need to allocate it to both 't-l' and 'pm'. I can not use actual names of products in rules, as there are too many of them and they change dynamically. Same applies to product managers.
I summed up the situation on the screenshot. I need a set of rules to fill the lower third of the table. Obviously, all numbers for all product lines of product type 1 will have to be doubled, for product type 2 - tripled. How do I do it for a large cube?
Re: Allocation best practice advice and help with rules need
For example:
['calculation']=N:['history'] * DB('forecast calc','forecast','PM Total',Elpar('t-l',!t-l,1)) \ DB('forecast calc','history','PM Total',Elpar('t-l',!t-l,1));
The associated feeder is simple and is left for you.
Sighurd
Version: 10.2.2fp6
Post by Sighurd »
Thank you very much! :)
I compared it to what I wrote trying to solve this problem and found my mistake. I used Elpar('t-l','!t-l',1) instead of Elpar('t-l',!t-l,1) and got all zeroes instead of right values. :oops:
Sighurd
Version: 10.2.2fp6
Post by Sighurd »
BTW, regarding feeders... Two top thirds of the cube on screenshot are imported from external sources. The last third is exported to another cube. I need only detailed values, I don't need any consolidations. Am I right in assuming that I can leave feeders section of the rules empty for this cube?
If you're only interested at level 0 in the cube (all white cells), you can omit the feeders.
Note that consolidations will not take place (isn't that the core business of TM1?).
Also, zero suppression will not work as intended.
But if you can live with that, you can skip the Feeders part.
Sighurd
Version: 10.2.2fp6
Post by Sighurd »
This is a "service cube", users won't ever see it. They will see the result in other cube and there will be consolidations. It is kinda special case, it does not even need to be loaded all the time, it's once-a-month-allocation. So yes, I can live with it. Thanks again.
Sighurd wrote:The last third is exported to another cube.
If you are using a view as your data source in the export you won't be able to use zero-suppression to limit the number of records.
Sighurd
Version: 10.2.2fp6
Post by Sighurd »
Out of professional curiosity and for the sake of experience I decided to finish set of rules and feeders for the above cube. The result is on attached screenshot. Seems to work correctly, but I wonder: is it optimal?
You are overfeeding.
Feed:
['history']=>['calculation'];
Or change calculation into a consolidation and add history as a child (the only one). Don't know if this does not compromise the rest of your TM1 model.
Or use TI to compute the allocation.
Sighurd
Version: 10.2.2fp6
Post by Sighurd »
Thank you, Wim. All good and valid ideas to think about. :)
