Remove "has sent you a notification:" in Application
bunchukokoy
OLAP Product: IBM Cognos TM1
Version: 10.2.2.x
Post by bunchukokoy »
Hi Guys! :D
I've been searching on how to remove this "<User> has sent you a notification:" from the subject part of the email notification every time there's an action done in the TM1 Application. It's kind of redundant, and I don't really need that to be there. It's using the first part of the subject line which is, should be the part where I should highlight the action done at user's first sight of the notification. Is there a way to remove this ?
And aside from the Notifications Setting wizard in the Performance Modeler, does it have a configuration file where in I can also modify or add some messages? I'm thinking of something like the ...\TM1Web\Web.config file. Is there any ?
Thanks for always giving replies. :D
Re: Remove "has sent you a notification:" in Application
Per the information on this page:
http://www-01.ibm.com/support/docview.w ... wg27035837
I don't think you can parameterize that part of the subject of the email.
bunchukokoy
Version: 10.2.2.x
Thanks Wim!
