TM1 10.2 and BI 10.2.1 security - did it wrong - part 1
Posted: Fri Sep 27, 2013 9:32 pm
Doing a TM1 10.2 install with BI 10.2.1 to provide Cognos security (AD). Ran into an issue in trying to change an application from 1 to 5. Set up links, gateway, services, etc (and did something wrong there) and could not add a C10 user into the security for the app - the Add New Client would not give the C10 security dialog prompt. I only got the native TM1 security box. After fumbling about, I ran across a workaround.
I set the security mode to 5; opened Architect while running as an account to have admin rights. Architect authenticated but then showed the limited set (sections but no objects). Closed Architect. Restarted application with security mode 1. Browse the security cube, could see the Cognos 10 user in the list. Gave it admin rights, then recycled the app to change security back to 5. I was then able to log into TM1 (all clients) using C10 security. Just thought I'd make a note here in case anyone runs into the issue.
(I only mention it as my dim memory makes me think you used to be able to add that admin account while in Sec Mode 1 - could be bad recollection though)
