Consolidated Element not found.
Tm1andTm1
Post by Tm1andTm1 »
Hi.
I am using "DimensionElementComponentAdd" to add element to consoldated, with the parameters.(No data source is used)
In Epilog :
DimensionElementInsert('Employee ID','',pEmpID,'n');
DimensionElementComponentAdd('IAG Employees',pposition,pEmpID,1);
While running TI is says "Consolidate Element not found", where as the value for consolidated element is present in the dimension.
please any one help me out.
Re: Consolidated Element not found.
You can't make metadata changes in the Epilog tab of a TI process. You can, however, shell out to another TI process that does that in it's Prolog.
Tm1andTm1
Post by Tm1andTm1 »
Hi Tomok,
Thank you so much for your early reply....
It was my mistake in writing script. It is done.
written script in prolog.
