Adding rights to application 10.2
flesh2011
OLAP Product: tm1
Version: 10.1.1
Post by flesh2011 »
Hi.
I`ve created a test application. approval.
Deployed and successful, but when I try to add rights in the rights tab it`s "blank"
Any Ideas?
Re: Adding rights to application 10.2
How is your security set up in TM1 itself?
What kind of groups do you have, what rights, ... ?
flesh2011
OLAP Product: tm1
Version: 10.1.1
Post by flesh2011 »
Hi.
I use Cognos 10 security and the cognos\everyone group is the only group in tm1.
I was excpected to se at least that group.
Suspecting there is something currupt in the application server files? pmpsvc?
Try importing a new security group for testing purposes, and see if it shows up.
flesh2011
OLAP Product: tm1
Version: 10.1.1
SOLVED Re: Adding rights to application 10.2
Post by flesh2011 »
Thanks for advice.
Just found out the issue. off course by scrolling in the install guide.
Basically tested by lowering IE security setting....
from guide that gave me the hint:
Configuring Internet Explorer for Cognos TM1 Web
If you are using IBM® Cognos® TM1® Web with Microsoft Internet Explorer, make sure you have this security setting enabled to allow Cognos TM1 Web dialog windows to display correctly.
Change the security settings as follows:
Allow websites to open windows without address bars or status bars.
Allow script-initiated windows without size or position constraints.
If Internet Explorer is not configured correctly, some Cognos TM1 Web dialogs can appear truncated.
Glad that you got it working now.
But I don't remember having to change these settings in the past.
