when i looked at TM1 logs i was able to see
When i restarted TM1 server TM1 clients and groups went missing from server( except Admin client ) .ERROR 2013-09-13 20:29:58.312 TM1.Blob CommitDeferredFileCommand - Open failed: err=5 system_err_code=5
ERROR 2013-09-14 07:00:43.757 TM1.Server sf_Rename: Failed to rename (g:\tm1\logs\tm1s.log) to (g:\tm1\logs\tm1s20130914070001.log). Error: Access is denied.
I copied clients properties cube from differrnt environment and reconfigured clients to concerned groups manually to fix this issue .
Does any one know extract reason why clients went missing from server .
Does any one encounter similar issue.
I am using TM110.1 on windows R2 2008 enterprise with no excel on the server
i included screenshot of TM1 logs in two instances .
Thanks for your time in advance.
