Hello TM1Forum,
I'm new to TM1, having only started to use it about nine months ago, and have found this forum immensely useful through this period, so i would firstly like to thank all the contributors.
So, to my first post:
I am using Cognos Express 10.1 through the Xcelerator add-in in Excel 2010, running on Windows Server 2008 R2 64-bit. In my active forms, i do not get the little red triangle graphic to tell me when i have applied a hold under the data spreading functionality. This also applies to any slice i make from a cube view. I do see the graphic if i apply a hold in the cube view itself.
Anyone come across this before? Any ideas for a solution? Makes using the numerous holds very difficult if you cannot see where they are.
Thanks.
