VBA Operators \ and /
Just thought I'd put this out there for people as it's just tripped me up as I have spent a while debugging VBA trying to understand why a division was always producing an integer result.
Through force of habit of writing TM1 rules using the "\" to suppress divide by zero I'd written
applyValue = (Target.Value - currentTotal) \ 12
for some custom spreading functionality in VBA.
From the VBA help
/ Operator
Used to divide two numbers and return a floating-point result.
\ Operator
Used to divide two numbers and return an integer result.
I thought I had some kind of data type problem as I was not getting the result I wanted but I had used \ in error and should be using /.
I didn't even know that \ was valid in VBA.
