Input month(MM) from TM1 perspective
Posted: Sat Aug 17, 2013 6:11 pm
by vins
Hi Experts,
Need Help !!
I am getting Month (MM format) from TM1 perspective. I have a month dimension and planning to add a following attribute to it and use it in rule.
Month Attribute
Oct -2
Nov -1
Dec 0
Jan 1
Feb 2
Mar 3
and so on.....
Please provide your inputs.
or please provide any generic approach to distribute the total cost over all the financial year months( Months changes from last year to current year).
Thanks & Regards
Vins
Re: Input month(MM) from TM1 perspective
Posted: Sun Aug 18, 2013 4:15 am
by Alan Kirk
vins wrote:Hi Experts,
Need Help !!
From the Request For Assistance Guidelines which you have been pointed to a few times now:
3) Try to make the question as specific as possible. A general question like "How do I write a rule?" is difficult to answer without copying out the whole of the user manual. A question like "I have a payroll cube which contains the following dimensions {details} and a general ledger cube which contains the following dimensions {details}, and although I've read through the Rules Guide I'm still not sure how to write a rule to give me average sales per employee" is far more likely to get the answer your need.
Trust me, that reply is a lot more gentle and subtle than the one that you would have received had you not deleted the one about "Please let me know the details of setting user level access to see specific set of data in TM1 application" that you posted half an hour ago; had you left that one up I can imagine the response that you would have received, especially from one quarter.
The most likely reason that you haven't received a reply to this thread (aside from the fact that you either haven't read or seem to be ignoring the RFA Guidelines and seem reluctant to take proper training in the product) is that I'm not sure that anyone can understand exactly what it is that you're asking for.
Posted: Sun Aug 18, 2013 4:39 am
by blackhawk
Alan,
You have way too much patience...
Vins:
It sounds like you are just getting started with TM1 and we all welcome that. However, I suggest you get started on reading more about TM1 before using the forums to educate you. Here is a great book to get started with: http://www.amazon.com/IBM-Cognos-TM1-Of ... 0071765697
After you go through this, I would suspect your questions would be answered.
Posted: Sun Aug 18, 2013 6:40 am
by vins
Thanks all for your precious suggestions, I will do lot of research by myself before posting it here.
Thanks for the patience !!!
Posted: Sun Aug 18, 2013 6:42 am
by vins
Thanks all for your precious suggestions, I will do lot of research and training on product by myself before posting it here.
Posted: Sun Aug 18, 2013 1:30 pm
by tomok
vins wrote:please provide any generic approach to distribute the total cost over all the financial year months( Months changes from last year to current year)
As others have already pointed out, read the manuals. Specifically, the TM1 User Guide and Chapter 6 - Using Data Spreading.
