Loading TM1 Error
Posted: Fri Aug 16, 2013 6:36 pm
by nmiller
I am helping a user load TM1 on Windows 7 and have been successful in 5 other previous installs. However i am running into an issue with one user and the error message is attached. Any help would be much appreciated!
Re: Loading TM1 Error
Posted: Fri Aug 16, 2013 8:40 pm
by jim wood
Are you running the install as an administrator?
Posted: Thu Aug 22, 2013 8:37 pm
by nmiller
Found out the solution was to delete any instance of Cognos on the local machine's registry. Once we did this, we reran and it worked perfectly!
