TI Process - Value Field Have Numbers and Strings
tgaluskapatterson
Post by tgaluskapatterson »
TM1 10.1
Window XP
Excel 2007
Architect TI Process
I currently have a TI process in place to copy budget information from an active version that rules run on to a static version. I am using the ViewCreate function to generate the view to copy my data from. The issue I am running into is the variable 'Value' has both number and string values. Example: 80.27 and 79550-0000 Even if I use the CellPutN and CellPutS functions not all the data will come over because the TI process doesn't recognize 79550-0000 as a number and blanks out the 'Value'. Thus no information is being copied over for any 'Value' in the following format XXXXX-XXXX. If i right click on the view and click"Export as text data" then uncheck the "Skip Consolidated Values" and "Skip Zero/Blank Values" and save the view I can get the XXXXX-XXXX to copy to the static version. I was hoping their is a automated TI process for a create view function that would include zeros and blanks. I looked at the information center and developer guide and couldnt locate anything.
Create Initial Views
s_cubCX = 'CapEx_Summary';
s_subSrc = 'zSysSubBudgCpySrc';
s_subTrg = 'zSysSubBudgCpyTrg';
#Patt_CapEx_Summary
ViewCreate(s_cubCX, s_vwSrc);
ViewCreate(s_cubCX, s_vwTrg);
ViewSubsetAssign(s_cubCX, s_vwSrc, s_dVer, s_subSrc);
ViewSubsetAssign(s_cubCX, s_vwSrc, s_dPer, s_subSrc);
ViewSubsetAssign(s_cubCX, s_vwTrg, s_dVer, s_subTrg);
ViewSubsetAssign(s_cubCX, s_vwTrg, s_dPer, s_subTrg);
Code To Copy from Active Version To Static
if (Capex_Measures@='Account');
CellPutS(Value, 'CapEx_Summary',Cost_Center,Target_Version,CX_Projects,CX_Category,Currency_Type,Period,Capex_Measures);
else;
# the value is numeric so convert it
MyValue=StringToNumber(Value);
CellPutN(MyValue, 'CapEx_Summary',Cost_Center,Target_Version,CX_Projects,CX_Category,Currency_Type,Period,Capex_Measures);
ENDIF;
Version: PA 2.0.7
Re: TI Process - Value Field Have Numbers and Strings
Post by jim wood »
Why not use the Dtype function? After all, the string values need to be within the last dimension. Just do a Dtype on the elements coming in from the view of that dimension. Then you just need to convert your if statement.
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Post by Duncan P »
You need to use Value_Is_String to determine which it is and then NValue for numbers and SValue for strings.
Version: PA 2.0.7
Post by jim wood »
Or you can do that... :D
