Is there any function in TI process to accumulate the values in tm1.I want only function so that we can manually write in TI process.
CellputN updates the values in TM1 if for the same record the value is coming. i want the values to addup through TI process. I dont want to select the option given in the mapping option.
I am unable to find the right function.Please suggest.
Accumulate function in TI process.
- jim wood
- Version: PA 2.0.7
Re: Accumulate function in TI process.
CellPutN(CellGetN()+Value,.....). If you use the GUI to auto generate the formula for you you'll get the same result.
- Michel Zijlema
- OLAP Product: TM1, PALO
Or CellIncrementN(Value, cube, dim1, ..., dimn) if you're on TM1 10.x.
Michel
Michel
dilip
- Version: 9.4
- Excel Version: 2003
Thank you very Much I got it.
