Active Form
Abinaya
Version: 9.5.2
Active Form
Post by Abinaya »
Is it possible to include a Attribute as a column in Active Form and include that in the rebuild? Say you want to update the attribute of the Dimension, so you include that in the Active form.
regards,
Abi
Re: Active Form
Anything you put in the top row of an Active Form (assuming that it's still inside the column range as defined in TM1RPTFMTIDCOL) will get "rebuilt", i.e., copied down as the form is redrawn. This includes values, Excel formulas, and TM1 formulas.
Abinaya
Version: 9.5.2
Re: Active Form
Post by Abinaya »
Thanks. Is that means, say we can use DBRA in a column and as long it's within the range of active form it will be updated for all the rows of the rebuild?
Re: Active Form
Yes
Abinaya
Version: 9.5.2
Re: Active Form
Post by Abinaya »
Thanks. Also I have loaded the Active form in the TM1 web as websheets. Now I did some changes to the data and saved using the button "Data Review
changes". Now I want to generate a exception report of the all the changes I did. How can I do this?
Should I try to read from log file?
