Hi Guys,
I have encountered a strange issue/bug today with RuleLoadFromFile function. I have a cube that gets built and destroyed on the fly with RuleLoadFromFile function in Epilog to load rule file to perform certain calculations.
If I copy the rule syntax into the rule editor Manually TM1 doesn't complain at all, but when I load it via TI I get this error:
Error: Epilog procedure line (8): E13) Error loading rules for cube "Cube Name" Syntax error on or before:
semicolon expected[/i]
Is it a known issue?
Thanking you in advance
Evgeny
RuleLoadFromFile weird behaviour
EvgenyT
- Version: PAL 2.0.8
Re: RuleLoadFromFile weird behaviour
Copying bit and pieces to a new txt file fixed the problem, but I am still puzzled with this behaviour... I got a feeling it has something to do with blank lines...
If anyone has an answer, would be much appreciated.
ET
ET
