Hi all
I have a cube thats 612373504 memory used, when i read the Statsbycube data this "apparently" is KB
http://pic.dhe.ibm.com/infocenter/ctm1/ ... ver_N60B3B
But when i do the conversion to GB its 584gb is this right? surely that cant be possible
Memory used is this right?
Re: Memory used is this right?
You don't have a 600 gig cube - which will probably cheer up your IT purchasing people.
IBM's doc is not correct - all stats in the Performance Monitor cubes are in whole numbers. I use the #,##0, format to scale them to thousands.
StatsByCube is in Bytes as far as I know.
- Excel Version: 2003 2007 2010 2013
thanks guys the Bytes seems more normal for the size but does that mean garbage memory is in bytes as well?
Yes
