Identifying user that launched a TI process
abetschen
OLAP Product: IBM Cognos TM1
Version: 9.1 SP3
Excel Version: Excel 2007
Post by abetschen »
Hi there,
I would like to know if there is a way to capture who ran a particular TI process. Currently I have a cube call ProcessLogs that capture information about a process (i.e. start time, end time, elapsed time, number of records processed, etc) I would like to capture and log who ran the process.
Any ideas on how to do that in a TI process? I tried to search this forum for a thread that would discuss this topic but could not find anything.
Thanks in advance.
Andre Betschen
Martin Ryan
Re: Identifying user that launched a TI process
Post by Martin Ryan »
The message log will tell you. Does that meet your needs, or do you need to put it in a cube for some reason?
abetschen
Version: 9.1 SP3
Post by abetschen »
I really would like to capture the user and put it into my cube "ProcessLog" that captures information about the processes. That way I can see at a glance when this process was last ran and who initiated the process. This would also make it possible to access this info via TM1Web. I work from home and accessing TM1 with the Excel addin over a WAN/VPN is quite slow.
There is the "TM1User" function starting with Version 9.1. But from what I have read in the documentation it only works in a spreadsheet.
May be there is not such a function for TI.
Andre
abetschen wrote:I really would like to capture the user and put it into my cube "ProcessLog" that captures information about the processes. That way I can see at a glance when this process was last ran and who initiated the process. This would also make it possible to access this info via TM1Web. I work from home and accessing TM1 with the Excel addin over a WAN/VPN is quite slow.
TM1User is a valid function for TurboIntegrator from 9.1 SP3 onwards. It's slightly different from the Worksheet function; with the worksheet function you have to specify the server name, with the TI function you obviously don't have to.
abetschen
Version: 9.1 SP3
Post by abetschen »
Thank you Alan.
I was able to get it to work and I now also found the reference in the technical bulletin that this function now works in TI with 9.1. SP3.
Andre
