File size in a TI
Darkhorse
Excel Version: 2003 2007 2010 2013
File size in a TI
Post by Darkhorse »
Hi all
Im writing a maintenance TI that checks for Files in the server folder. I can count them, using scan i can define them but is there anyway to get the file size? or second to this any way i can get the folder size as well?
Thanks all
Re: File size in a TI
Hello there
I'm not sure there's a direct way in TI. If yes, I would like to know about it too.
What I did in the past, was create a VBS file, execute that file with TI, let the VBS create a text file, and pick up the file again in the next TI process.
Wim
Darkhorse
Post by Darkhorse »
hi wim,
I too built a Excel VB document to do this however im trying to move away from the need to run macros and automate my Maintenance via chores
What I suggested above, is no Excel and macros, and can be automated through chores.
Darkhorse wrote:Hi all
Thanks all
You can get a file listing with sizes by issuing a DIR command in a TI process. You can then parse that file in a second TI. There are a bunch of parameter options you can provide to the DIR to get the file in the format you want. To get all the files in a data directory and all subfolders and files you could do this:
CommandLine = 'cmd /c dir /s *.* >File_Listing.txt';
ExecuteCommand(CommandLine, 0);
This will produce a file list in the default directory in TM1. If your data folder is not the default you may need to provide a folder to the DIR command. A second TI can parse File_Listing.txt, creating a File dimension and writing the particulars of each file to a cube.
Darkhorse
Post by Darkhorse »
Brilliant i like it
thanks guys :D
