Is it text or number (TI Question)
TomHine
Version: TM1 9.1
Excel Version: 2003 - 2007
Post by TomHine »
I'm using TM1 9.5 and writting a new TI process for data import.
The system I'm importing from is a single ledger system and therefore when I extract the data it shows all the nominals with balances but also all of the debtor/creditor accounts. All of the dr and cr accounts begin with a letter whereas all of the nominal accounts start with a number.
I'd like to consolidate the dr and cr accounts by using a if formula to ascertain whether the string starts wiht a letter or a number. Does such a function exist in the functions, I can't see one?
Tom
Re: Is it text or number (TI Question)
Post by David Usherwood »
I'd suggest picking up the first character using subst(xxx,1,1) and testing whether it is between 0 and 9 inclusive.
TomHine wrote:Hi,
You can use the Code Rules function to determine the ASCII code of the first character. If the code falls between 48 and 57 inclusive, it's a digit.
Edit: 3 independent replies within 4 minutes. That's service with a smile.
(David beat me only because the Reference guide was really slow to provide the link tonight. ;) )
Hi Tom
If(Code(youraccount,1)>=48 & Code(youraccount,1)<=57);
# this is a number
EndIf;
or:
If(Subst(youraccount,1,1)>='0' & Subst(youraccount,1,1)<='9');
# this is a number
EndIf;
Or another variation:
If(Scan(Subst(youraccount,1,1),'0123456789')>0);
# this is a number
EndIf;
Wim Gielis wrote:Or another variation:
# this is a number
EndIf;
Awesome code snippet.
AmbPin
Version: 9.5.2
Excel Version: 2007-10
Post by AmbPin »
If you wanted to check the whole string one way might be:-
sTestString = '1234a';
nStringPos = 0;
While(nStringPos < Long(sTestString) & nStringPos > -1);
  nStringPos = nStringPos + 1;
  If(Scan(SubSt(sTestString, nStringPos, 1), '0123456789') = 0);
    nStringPos = -1;
  EndIf;
End;
If(nStringPos > 0);
# This is a number.
EndIf;
