Process Worksheets - recent experience
Posted: Fri Apr 10, 2009 1:27 am
Has anyone run into the following situation that I found:
I am aware that Cognos has "deprecated" offering Technical Support for Process Worksheets in 9.4.... but I had a recent client upgrade from 9.0.2 with Process Worksheets to 9.4.MR1 (the client's prior license did not include Turbo-Integrator). Client continues to be Excel-centric, and had 2 PWs they wanted to retain in the upgrade.
One PW was configured for a flat file and ran successfully but significantly slowly in 9.4.
The other PW was ODBC-based (SQL view) and could not load the data to TM1 correctly. Each element "address" was truncated differently (pattern per dimension) and all intersections failed to match. SQL database permissions were in place, DSNs were fine, but no luck.
Curious if any other TM1 sites have seen this behavior (I know, I know, who would want to, there's no need, etc.)
- Thanks in advance
- Thanks in advance
