Excel workbook slow "first time" open with TM1 9.5.2
Posted: Wed Jul 10, 2013 11:11 pm
I have recently experienced an issue where a particular excel workbook is slow to open the first time opened in the day however is fast to open without loggin onto TM1. Characteristics of the issue include
1: File opens quickly <1 second if I have not logged into TM1. (TM1 addin live just not logged in)
2: File open time approx 1 minute if loggied on to TM1
3: If I re-open the file after closing (but not logging off the network), it then opens quickly (compared to first time open 1 minute)
4: If I open without being logged onto TM1 < 1 second, then log onto TM1 the TM1 logon process takes approx 1 minute
5: Same experience on multiple PC's. Logons
6: Auto calcualtions are not on for the above. (TM1 does nto calculate at open)
7: I have tried sample deleting Tabs on the file and still experience the issue
8: No at open macro's in the workbook
9: I have minimised the file size (it is similar to many other workbooks I use)
Has anybody seen this type of event before or could you help with suggestions on how to troubleshoot and resolve the issue. My next step will be to copy Tab by Tab to a new workbook, log off and open again to see if a particular Tab is causing the problem. Due to requiring log off each time this will be a slow process.
My theory is the file is loading something??? into local memory on first time open with TM1 loged on (that speeds up subsequent file opens) but I cannot pinpoint it.
