This function will return the first instance of the element within the subset. You could search for the last instance by reversing the loop, or include an additional counter to count for the Nth instance in the subset.
Parameters:
pDim - A valid dimension name.
pSubset - A valid subset name in pDim.
pElement - The name of an element within the dimension.Code: Select all
## SUBIX ######################################################
## Intended Functionality: SUBIX(dimension, subset, element)
## Usage: ExecuteProcess('SUBIX', 'pDim', DIMENSION, 'pSubset', SUBSET, 'pElement', ELEMENT)
## SUBIX stores the index number of an element within a subset in the global variable 'gSubixReturn'.
## If the element is not found within the subset, gSubixReturn is set to -1.
## Before calling, be sure to include the line 'NumericGlobalVariable('gSubixReturn');' in the parent process.
i = 1;
nMax = SubsetGetSize(pDim, pSubset);
gSubixReturn = -1;
WHILE(i <= nMax);
IF( SubsetGetElementName(pDim, pSubset, i) @= pElement);
gSubixReturn = i;
i = nMax;
ENDIF;
i = i + 1;
END;
