Every time I try to attach this rule, I get an error for an Invalid Expression, starting at ['Actual':
['Forecast1','String Value'] = S: ['Actual','String Value'];If I set the rule to a Literal, like this:
['Forecast1','String Value'] = S: 'Hello World';Code: Select all
['Forecast1'] = ['Actual'];I'm working in a small dev cube so that I can port this to a larger cube, so there are no other rules on the cube. Is there something obvious I'm missing?
Thanks in advance for any help.
I'm running 10.1
