Chore Security Maximum Ports
Darkhorse
Excel Version: 2003 2007 2010 2013
Post by Darkhorse »
Hi all
Probably a quick one for you but a head scratcher for me, I have a process that sends "3" to the maximum ports for my clients in the clients properties cube, Works brilliantly when I manually run it, I had a chore setup to run this process but i get a security warning on sending to this attribute, Am I missing something here? I always thought the Chore was ran as an admin on the server or is this a protected attribute that cannot be chored due to higher level securities
thanks all for reading looking forward to hearing a response
Re: Chore Security Maximum Ports
Right-click on the TI and press the "security access" option.
See here for details:
http://publib.boulder.ibm.com/infocente ... tyDat.html
HTH
Darkhorse
Post by Darkhorse »
wow something that simple
thanks for the response, tried tested and worked, thanks for the link as well
