I've installed TM1 9.4.0 on XP using Excel 2003. I can connect to the sample and custom databases thru Perspective and Architect but when I'm attempting to use the web I get the following msg after entering the URL: TM1APIDOTNET Exception: - Cannot find security service. I can choose the instance and enter in my username and password but the Login button is disabled. Any ideas?
Thanks.
Re: TM1APIDOTNET Exception: - Cannot find security service.
Resolved. One of my instance was using PortNumber 123456 which is the same as the ClientMessagePortNumber. Once I changed it no more msgs.
rlapper
- Version: 9.4
It would also appear that if you attempt to change the integratedsecurity setting in the Tm1s.cfg file then you get his error until yourun the repair facility on the install
