How to disable/hide Cognos Insight launch icon from TM1 appl
tm1novice
Post by tm1novice »
Does anybody know how to hide the Cognos Insight icon from TM1 application portal ?
In Cognos BI we can modify xml files to remove the related elements to hide the elements from the portal ?
Is the same possible in TM1 application portal ?
Thanks.
Version: PA 2.0.7
Re: How to disable/hide Cognos Insight launch icon from TM1
Post by jim wood »
I've never tried it but the Application front end is built around similar technology so I would be surprised if you can't do it.
