I noticed in our message log that every event is producing 2x duplicate messages in the log - which is dramatically increasing our log file size :p
...below is our tm1 log properties file - am trying to figure out if there is any parameter in there that is causing the messages to duplicate... so if anyone has any ideas, please let me know
thanks!
Matt
# Enable INFO level logging through the shared memory appender, by default. The server
# will write informational messages, as well as errors and warnings to the log file.
log4j.rootLogger=INFO, S1
log4j.logger.TM1=INFO, S1
# S1 is set to be a SharedMemoryAppender
log4j.appender.S1=org.apache.log4j.SharedMemoryAppender
log4j.appender.S1.File=tm1server.log
# Specify the size of the shared memory segment
log4j.appender.S1.MemorySize=5 MB
# Specify the max filesize
log4j.appender.S1.MaxFileSize=20 MB
# Specify the max backup index
log4j.appender.S1.MaxBackupIndex=20
# S1 uses PatternLayout
log4j.appender.S1.layout=org.apache.log4j.PatternLayout
log4j.appender.S1.layout.ConversionPattern=%t %p %d{%Y-%m-%d %H:%M:%S,%Q} %c %m%n
# Specify GMT or Local timezone
log4j.appender.S1.TimeZone=Local
