Creating lot of roles
ioscat
OLAP Product: Contributor
Version: 9.5.2 10.1.1 10.2
Excel Version: 07+10+13
Post by ioscat »
Hello, community.
How do you create lot of roles and how do you put people to them? Do you use standart incredible mouseclicking operations thousands times?
Searched forum for "create roles" - couldn't find solution
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Re: Creating lot of roles
Post by Duncan P »
Do you mean roles or do you mean groups?
If you mean groups then a search for "create groups" turns up quite a lot (as does the documentation - Security TurboIntegrator Functions).
If don't mean groups could you give a bit more detail please?
ioscat
Post by ioscat »
I mean roles in contributor for submitting, editing, or business roles like London Shop Super Top Manager
Hello
If I'm not mistaken, you could add a role manually, and export a file (XML format I think).
Then open up the file, copy/paste lines for example, or generate the contents in Excel using simple formulae or macro,
and paste the contents in the file. Then import the modified XML file again.
