I am setting up integrated login on a TM1 server for the first time. It works very well for single users where I set UniqueID to user@domain in the }ClientProperties cube (I am not using the ETLDAP utility). My question is if you, instead of a single user, can map a client in TM1 to a user group on the domain? I have tried using group@domain and domain\group as UniqueID but that did not work. I can't find any information on how to find the domain-qualified name of a user group. Do you know if what I am trying to do is possible, and if so how to get it right?
Thanks!
/Bergstrand
Integrated login and user groups
- OLAP Product: TM1, SSAS
- Version: 10.2
Re: Integrated login and user groups
Interesting idea - but I think for IL, users in TM1 have to be users in the LDAP source - since IL uses the source for authentication, it needs to ask for a user not a group.
- Version: 10.2
Ok, that's why it doesn't work then.
Too bad - it would have made our user administration simpler.
Thanks for your fast reply, David!
- Version: 9.0 and up
- Excel Version: 2007 and up
1. If you use this code in a batch file an execute it from the command prompt the User and Domain will be returned in the way you need it for the UniqueID if you use NTLM.
echo off
cls
echo .
echo .
echo .
echo User: %username%
echo Workstation: %computername%
echo logon to: %logonserver%
echo Domain: %userdomain%
echo profile: %userprofile%
echo .
pause
2. Your TM1 user does not need to be a LDAP user. You can for example have a TM1 user 'IdontExist' with yourwindowsid@domain in the UniqueID and it will log you in as that TM1 user.
3. As far as I know you cannot use groups in the Unique ID, it is always user@domain. You wouldn't be logged on as a group onto to your machine, would you?
Gregor
echo off
cls
echo .
echo .
echo .
echo .
pause
Gregor
