TM1 perspectives Conditional formatting is lost after saving
Posted: Tue Jun 04, 2013 7:37 pm
by LutherPaul
TM1 perspectives Conditional formatting is lost after saving or uploading into applications.
There are other applications with Conditional formatting that have no issues. I have not created them, by my predecessors did.
After conditionally setting the color, it works fine for the forst time. After I save it locally and refresh, the condition is missing at times and other times, the conditional format is after current result set is displayed. Am I missing any condition?
I tried to upload the spreadsheet server. Same thing formatting is lost. Please let me know your answers.
LR
Re: TM1 perspectives Conditional formatting is lost after sa
Posted: Tue Jun 04, 2013 8:18 pm
by Alan Kirk
LutherPaul wrote:TM1 perspectives Conditional formatting is lost after saving or uploading into applications.
Are these standard slice-based workbooks, or Active Forms?
Posted: Tue Jun 04, 2013 8:39 pm
by LutherPaul
Active Forms.
Posted: Tue Jun 04, 2013 8:57 pm
by declanr
LutherPaul wrote:Active Forms.
And was the conditional formatting placed within the formatting range (rows 1 - 10ish) or was it in the actual data rows?
When the active form is rebuilt, any formatting placed in the data rows will be overwritten with what is in the formatting range.
It is also worth noting that if you view the sheets through TM1 Web there is a limit of 3 conditions for conditional formatting per cell, so if you have (in order):
1/ If Cell = 1 then Green
2/ If Cell = 2 then Blue
3/ If Cell = 3 then Red
4/ If Cell = 4 then Purple
and the cell in question did equal 4, the conditional formatting would be ignored and it would just take the generic cell format - if however it equaled 1, 2 or 3 then it would adopt the conditional format.
The 3 max could perhaps just be when you are saving the workbooks as 2003 format though (which I do for a number of other TM1 Web oddity reasons.)
Posted: Tue Jun 04, 2013 9:53 pm
by LutherPaul
Thanks for the reply Declan.
I am trying to apply formatting to the data region. Ho do we set "formatting range" to be dynamic? formatting works first time when rule is set, after reloading, the formatting is lost.
LP.
Posted: Tue Jun 04, 2013 10:29 pm
by tomok
LutherPaul wrote:Thanks for the reply Declan.
LP.
Read the TM1 User Guide, Chapter 8 - Active Forms.
Posted: Wed Jun 05, 2013 3:40 pm
by LutherPaul
Chapter 8 worked. Thank you.
