Perspective NOT working in TM 10.1.1
roy2087
OLAP Product: cognos tm1
Version: 10.1.1
Post by roy2087 »
Hi ,
My Cognos TM1 Perspective is NOT working.
It is hanging after the pop-up "Enable Macros"
I am also using a 32-bit Microsoft Office.
Any advice.
Attached is the Screen Shot.
Version: PA 2.0.7
Re: Perspective NOT working in TM 10.1.1
Post by jim wood »
Have you tried applying FP1 for 10.1.1?
roy2087 wrote: My Cognos TM1 Perspective is NOT working.
Any advice.
I'm not seeing any hang there; the title bar of Excel doesn't seem to be ghosted. I'm not sure what the icon on the task bar to the left of Excel is; whether it's Server Explorer or a local server session. More likely the latter I imagine given that I don't see either a TM1 tab or an Addins tab on the ribbon.
Did you actually install TM1 client on this machine? As in, not just put the folder containing the .xla on the C:\ drive somewhere and then tried to open it, but actually ran the installation package selecting the Client application as part of that install? Did you do the install with Administrator rights? If the answer to either of these is no, I'd suggest doing that.
roy2087
Version: 10.1.1
Post by roy2087 »
Hi Alan Sir,
I have installed the TM1 Client using Admin Rights.
Its working fine now.
Roy.
