1. I noticed several process reported in TM1 message log when running FAP initial update, that are not present in TM1 model directory. Does anyone knows where they come from? Are they created and deleted dynamically? (for example: deleteallfapgroups_process, etc..) Is there a way to check and\or change them?
2. I noticed that when reported value in controller is entered in a way that contradicts definitions in linked structure, it is not copied to TM1 with FAP, although it can be saved in controller. Did anyone experienced the same behaviour?
FAP questions and observations
- Excel Version: Office 2010
Re: FAP questions and observations
Hi vladkon,
If you are in Architect/Perspectives, select View > Display Control Objects.
This will reveal a large number of objects, including cubes, dimensions, and processes, that are prefixed with '}' - this indicates that they are system objects
Once they are exposed you can view them as you would other objects.
thanks Christopher, of couse I checked display control objects - that's what was strange with these processes - they are not there..
