I am in architect 10.1 writing a rule. I am trying to automate my cube so if I enter a value in the 'System_ProcessInfo' cube it will update all the current FY in my code that were previously hard coded. In other word one entry point to roll my months and years.
Old Code
['Current Budget','Period Input','Variance Budget Basis $']=['Current Budget','FY 2014','Amount (LC)']-['Budget Basis','FY 2014','Amount (LC)'];
New Code
['Current Budget','Period Input','Variance Budget Basis $']=['Current Budget','FY'|' '|'20'|DB('System_ProcessInfo', 'stringValue23', 'Patt_Admin'),'Amount (LC)']-['Budget Basis','FY 2014','Amount (LC)'];
The code works just fine if I enter 'FY 2014'. However if I attempt to automate using 'FY'|' '|'20'|DB('System_ProcessInfo', 'stringValue23', 'Patt_Admin') it will not work. I am using this same code for other rules in the same cube so it seems strange. For some reason it appears not to be recognizing the concatenation bar | .
The error i receive is below.
Error:
Error on line 82:
Element Not Found "FY"
tgaluskapatterson
Duncan P
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
Re: Element Not Found "FY"
Element names within [ ] cannot be expressions, either on the left or the right of the =. You will have to use a DB( ... ) instead.
If you have used this exact technique in another place and it has worked then I would very much like to know the exact details, as it really shouldn't have worked.
- jim wood
- Version: PA 2.0.7
Bloody hell Duncan you were quick. I barely got time to hit reply!!!
- jim wood
- Version: PA 2.0.7
Also post moved. Enhancements is not meant to be a forum for coding questions. Please keep all coding questions with the main TM1 forum. Please refer to the request for assistance guidelines announcement.
tgaluskapatterson
Appreciate the help. This worked great. It appears the other code i used was in a DB reference just didn't realize I couldn't use in a standard equals formula. Thanks!
