In TM1 version 10.1.1, it looks TM1 Application Web portal is using fully qualified domain name of the server machine for the URL addresses of some portal components although I have not specified fully qualified domain name of the server in anywhere in TM1 configuation. In our case, the server is not accessible with the fully qualified domain name in the network although server is in the domain. It is accessible with IP and server name. Therefore TM1 Application Web is not working properly in client browsers. TM1Web works all ok. TM1 Application Web works ok in the server browser as the fully qualified domain name is accessible in the server itself.
How can I stop TM1 Application web using Fully Qualified Domain name of the server in the URLs of portal objects? and make it use either server IP address or server name without domain suffix?
