I've got a problem - i need to run a TI process from Java and this is easy. But when i do it my process doesn't see publishing of my package - i'm using Framework Manager.
Everything is fine when i'm running process by an Architect - but i have to do it automatically. What is more i found that everything is fine when i only open my TI process, save it without any chasnges and close - then i can run process outside Architect and i see 'fresh' data.
I know where the problem is - in .blb file for each cube there is a date of publishing a package - but it is another date than is in FM log file for example - it has a hundredth part after the dot and this date is changing only when you open TI process in Architect.
I need to do something that process running from Java can see when i publish a package - now it is only seeing when i first open process in Architect.
May be there is a way to publish package from Java or .Net?
I don't know if You understand me, but i hope so
Michael
